Rim Size Questions
Old 02-07-2012, 07:36 PM
Hylander7's Avatar
Hylander7
Hylander7 is offline
Default Rim Size Questions
So my 99 has 16" wheels
I asume I run 17's
Is there any benifit or downside ?
Reason I ask is I like the style of this 17" better.
I can gets these tires and wheels for $600 or less
They are 285/70R17
Old 02-07-2012, 07:50 PM
stewie01's Avatar
stewie01
stewie01 is offline
I put the same wheels on my truck and wrapped them in Wrangler Authority's. The wheel/tire combo may be a bit heavier then the smaller 16, but I can't think of any downside to running 17's instead of 16's.
Plus these wheels were only available on the Off Road Edition Ram, so they sorta special!
Old 02-07-2012, 07:52 PM
merc225hp's Avatar
merc225hp
merc225hp is offline
OP 16" tires are getting harder to find and up here are more $$ than the 17". Good deal! I would say grab them. OP Just a tip " = inchs '= feet I don't think they make a 17' rim for our trucks lol.
kejobe's Avatar
kejobe
kejobe is offline
Shouldn't make a bit of difference. As long as the tires overall diameter is the same as stock your speedo will be correct. If the new tire is taller, the speedeo will show slower than you are really going. By how much depends on the difference in size.
Other than that, there's no problem.
Old 02-07-2012, 07:54 PM
stewie01's Avatar
stewie01
stewie01 is offline
16" tires are getting harder to find and up here are more $$ than the 17". Good deal! I would say grab them. Just a tip " = inchs '= feet I don't think they make a 17' rim for our trucks lol.
I used the ' as an apostrophe and not to suggest foot or inches.
Old 02-07-2012, 07:57 PM
stewie01's Avatar
stewie01
stewie01 is offline
I went from a 245 to a 265 and according to my GPS (which may be wrong too) my speedo is anywhere from 2-3MPH slower... Who knows...
Old 02-07-2012, 08:06 PM
kejobe's Avatar
kejobe
kejobe is offline
Yup. I'm still on 16's but went from 245/75 to 265/75. Now when I'm doing 60 my speedo says 57. It doesn't bother me though.
Old 02-07-2012, 08:07 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
there's over $600 worth of tires alone in that stack. GRAB THEM.
after you wear out those tires, you can sell the wheels for another $300-400.
Old 02-07-2012, 08:08 PM
merc225hp's Avatar
merc225hp
If I was refering to you I would have quoted your post. Quoted from the op post "Reason I ask is I like the style of this 17' better."
Old 02-07-2012, 08:14 PM
stewie01's Avatar
stewie01
stewie01 is offline
My bad, hard to tell with all the ' floating around out there
Quick Reply: Rim Size Questions
