NP241LD - Where's this snap ring go??
Old Feb 9, 2012 | 05:54 PM
Wombat Ranger's Avatar
Wombat Ranger
Originally Posted by BackwoodsRam
it happens some times. the ring possibly worked its way around until one of the ends was sitting next to one of the little golden humdingers and then worked its way loose/out
edit: hey 2x can you get me the parts numbers for parts #17, 45, 8, and 4?
Considering that's the whole external aluminum case, wouldn't you be better off getting a whole case used somewhere?
Old Feb 9, 2012 | 05:59 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by 2x1972
Thanks I like it too!
Well other then some chunks that came from the busted "Rear bearing retainer housing," part 8, everything looked great inside. I'm just trying to figure out how the syncro spring ring (that's a mouthful) got loose on its own...
Am I interpreting the diagram right in that the said spring is b/t the forks? Would there be enough play in those to have them bind or impact that spring?
Old Feb 9, 2012 | 06:02 PM
Wombat Ranger
I don't think so... I guess we'll see when i tear into it this weekend. I wish i could do it tonight, but i'm stuck here till 6
For about 700 miles the truck was driven with no rear snap ring (the common one everyone talks about). I bet it was during this time that it worked it's way loose, with nothing holding everything together.
