tcc solenoid how to replace it... NEED HELP ASAP PLEZ ......
Old Feb 11, 2012 | 09:52 AM
  #21
How's the TPS?
Old Feb 11, 2012 | 10:40 AM
  #22
lowenasty 08's Avatar
lowenasty 08
My b lol what's that...
Old Feb 11, 2012 | 10:48 AM
  #23
Throttle position sensor. If it is getting erratic, it will cause TCC to 'bounce'.... (engage/disengage fairly quickly)
Old Feb 11, 2012 | 03:25 PM
  #24
Augiedoggy's Avatar
Augiedoggy
uh, if you have no shifting problems changing the soleniod isnt going to fix anything....I suggest you take it to a shop.... If your rpm's are surging when its not shifting you may have bands way out of adjustment or a torque converter about to fail...
Old Feb 11, 2012 | 04:55 PM
  #25
lowenasty 08
Where is that sensor at...
Old Feb 11, 2012 | 06:01 PM
  #26
PapaG's Avatar
PapaG
I'm assuming you are asking about the TPS that HeyYou was talking about. The TPS is located on the throttle body.
Old Feb 11, 2012 | 07:15 PM
  #27
lowenasty 08
Left or right side ...
Old Feb 11, 2012 | 09:14 PM
  #28
lowenasty 08
What would yall do to fixe it????
Old Feb 11, 2012 | 10:10 PM
  #29
gdstock's Avatar
gdstock
Test it with ohmeter as indicated in FSM. If it is bad, replace it. Reading should be smooth and consistent.
Old Aug 18, 2012 | 01:18 PM
  #30
polarb3329@msn.com's Avatar
polarb3329@msn.com
New Member
I am stranded in Bozeman ,MT with a tcc problem myself.....no shops fix on weekends . I heard that changing the fluid was a terrible idea, and it might be the cause.
Regardless, hopefully it doesnt break the bank :-/
