tcc solenoid how to replace it... NEED HELP ASAP PLEZ ......
Old Feb 10, 2012 | 10:41 AM
lowenasty 08's Avatar
lowenasty 08
Default tcc solenoid how to replace it... NEED HELP ASAP PLEZ ......
I got a 99 dodge 1500 4x4 with a bad tcc solenoid n the transmission is there any websites that have schematic or a lay out on how to replace one.....
Old Feb 10, 2012 | 11:28 AM
bjr1a's Avatar
bjr1a
The mitchell1 manual online is an excellent repair manual with different options on pricing.....the valve body must be removed to replace the tcc/od solenoid assembly ...However it is very uncommon to have a bad tcc solenoid..Are you 100% sure its faulty?
Old Feb 10, 2012 | 11:40 AM
lowenasty 08
my rpm's r fluctuating and my check engine light cam on ... transmission shop wants 2000 to mack it like new.....
Old Feb 10, 2012 | 12:04 PM
bjr1a's Avatar
bjr1a
what code was extracted?
Old Feb 10, 2012 | 02:44 PM
lowenasty 08
Can't remember .... :-(
Old Feb 10, 2012 | 02:59 PM
stewie01's Avatar
stewie01
If your just replacing the TCC/OD Solenoid Assembly then you don't have to drop the valve body, if your replacing the solenoid itself then you have to drop the valve body. Which are you replacing?
The TCC/OD Solenoid Assembly is what connect's to the 8 PIN Connector on the outside of the transmission above the neutral safety switch.
Old Feb 10, 2012 | 07:35 PM
lowenasty 08
I was told the tcc solenoid the rpm's. fluctuates when im driving and uses a lot more gas to.. i was told its the one n the valve body.....
Old Feb 10, 2012 | 07:37 PM
usually comes as a set, on a bracket, with the o/d solenoid as well...... I have heard rumors that you don't have to drop the v/b to change these......
Old Feb 10, 2012 | 09:20 PM
lowenasty 08
Is there a website that i can go to to git a lay out of the tray.... and how to replace it....
Old Feb 10, 2012 | 09:29 PM
stewie01's Avatar
stewie01
Yup, if your just changing out the assembly you don't have to drop the valve body, there is a plate by the governor solenoid (I think) you have to drop lose to get to the screws that hold the bracket in place, and on the drive side there is a piece (name?) that bolts to the side of the valve body, you remove that piece, when you do a spring will shoot out the side at you, once the piece is off a large spring will fall out and then a cup like thingy will fall down, and walla there is the 8 pin connector.
Really it should take about 15-20 minutes change out the assembly once you've gotten to that point. Do be CAREFUL the clips that hold the connector's to the governor solenoid break very easy. Ask me how I know.....
I bought my assembly from the dealer, no tcc/od solenoid included.
