Found strange steel ball
Old Feb 15, 2012 | 11:28 PM
bill022572's Avatar
bill022572
Default Found strange steel ball
HI - just tore down my 2001 Ram 1500 2wd 46re last weekend. I am in the process of getting my parts together for re-assembly. But ----- tonight I was putzing around looking at the many parts and noticed something strange. When I removed the valve body assembly --- I sat the whole assembly in the trans pan and had it sitting on my bench waiting to be cleaned (it has not been dis-assembled yet). I saw in the pan under the valve body mixed together with the pan bolts : a steel ball. Any ideas where it could have come from ? Has anyone ever run into this before ? I am planning on a more thorough and closer look tomorrow but was just wondering. Thanks
Old Feb 15, 2012 | 11:33 PM
gdstock's Avatar
gdstock
There are about 5 steel ***** in the valve body. But that's the key - they should be IN the valve body.
Go here and download. Go to tranny section. The steel ***** are 3 different sizes. The only one that is outside of the internals is the deten on shifter comb.
2nd Generation Dodge Ram Service Manuals
Old Feb 16, 2012 | 11:13 PM
bill022572's Avatar
bill022572
Thanks for the reply - I really appreciate it. And --- GOOD CALL --- I went and looked at it again and that is exactly what it was. When I removed the linkage - I originally made a mistake and removed the clip that holds the manual shaft in - I had realized my mistake and reinstalled it but when I had it out the manual lever had apparently moved out enough to let the ball come out. A miracle I didn't lose it. Again - thanks for the help.
