Fuel Rail Removal
Old Feb 16, 2012 | 10:27 AM
i mow grass's Avatar
i mow grass
Default Fuel Rail Removal
Well I am right smack dab in the middle of my spring tune up/repair. I am going after the plenum, but I seem to be stuck on removing the fuel rail/injectors I have bled the rails per service manual. Everything that I have read on here says I should just be able wiggle both sides of the rail assembly out all at once. Am I just not using enough force or am I missing a piece that I was supposed to remove. Again thanks for all the help guys.
Old Feb 16, 2012 | 10:34 AM
drewactual's Avatar
drewactual
after you remove the four bolts- one in each corner...put a long shanked screw driver under the rail and the blade on the intake manifold.. pry slightly.. start at the far end.. move it up a little, work your way back, prying slightly.. try to take it off as evenly as you can.. they can be a biyatch for sure..
you know, though, you don't have to take the rail off, right?
Old Feb 16, 2012 | 10:46 AM
i mow grass
Really, Will I still be able to pull the kegger all the way out and cleaner throughly without any damages to injectors? I will at least have to pull the fuel line I am guess though.
Old Feb 16, 2012 | 10:47 AM
drewactual's Avatar
drewactual
yup.. release the fuel line at the rail, back drivers side.. leave the rail in place.. if you're going to dunk it, I'd pull the injectors.. if you're just going to scrub it good- you will be alright.
Old Feb 16, 2012 | 10:50 AM
Pronk's Avatar
Pronk
Yeah if you leave the fuel rails on you have to remove the fuel line, which requires a special diconnect tool you can get at most auto parts stores. But I think most people just disconnect the fuel line, it seems to be the easier way.
Old Feb 16, 2012 | 11:04 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
On the 1997, the "special disconnect tool" is called a two fingers and two thumbs.
Old Feb 16, 2012 | 11:14 AM
i mow grass
Thats my kind of tool! Same for the 01s?
Old Feb 16, 2012 | 01:53 PM
4angrybadgers's Avatar
4angrybadgers
I had to pull really hard on my rails (straight up, of course!) to get them out of the kegger. I had replacement injector O-rings on hand, and fully expected to tear the originals when I realized how stuck they were. Didn't break any O-rings, amazingly, and the injectors stayed in the rail. When I re-installed the rail, I lubed the bottom O-rings with a very light coat of motor oil, and they went in fairly easy.
I just had a thought. WD-40 helps with sliding rubber hoses on/off connectors - would it help with pulling the fuel rail+injectors out of the plenum?
Old Feb 16, 2012 | 01:55 PM
It should.
Old Feb 16, 2012 | 03:35 PM
stewie01's Avatar
stewie01
Nope. Require's a special tool, don't know the exact name as we just made something from scratch to get the line off the rail.
