1999 Catalytic Converter Problem.
Hi everyone!
I've been having a problem with my Dodge's catalytic converter. It's been giving an error code "420 - Catalytic Converter Efficiency." I replaced both O2 sensors twice. I've replaced the cat with a Magnaflow High-Flo cat twice, each lasted maybe 3 months before the error code came up again. I then took it to a second exhaust shop that told me the Magnaflow did not work because it was only OBD I compliant and he put a Catco brand catalytic converter on it. Well it's been on maybe 2 weeks and the code has showed up again.
Has anyone else ever had this problem or know what's going on?
I got a 1999 Dodge Ram Sport with a new 5.9L 360 with maybe 5,000 miles on it and it's gone through the Magnaflow and Catco cat. It originally had a 318 for 140,000 miles and it went through the stock and Magnaflow cat.
Thanks!
Thanks!
I'm using Bosch 02 Sensors from Autozone.
Could the plenum be bad? I had the shop replace all the gaskets and got a new stock intake manifold when I had the new 360 put in my truck.
