Check engine light after fuel top up
Old Feb 23, 2012 | 05:46 PM
ZeroZero3's Avatar
ZeroZero3
Default Check engine light after fuel top up
I wish I have a code reader for this one. Any idea why my check engine light come on after everytime I stop at the gas station. Evap. system maybe??
Old Feb 23, 2012 | 05:53 PM
check your gas cap.
Old Feb 23, 2012 | 05:58 PM
gdstock's Avatar
gdstock
+1 on gas cap and if it is good, then evap system.
Old Feb 23, 2012 | 07:45 PM
dhvaughan's Avatar
dhvaughan
do the ignition key trick.
on - off - on - off - on
read the codes in the odometer window.
Old Feb 23, 2012 | 09:20 PM
ZeroZero3's Avatar
ZeroZero3
I tought that the on-off trick was for the Dakotas only, good to know.
As for the gas cap it's on tight for sure, so unless it's craked ... I'll check it closely.
More to follow, thanks.
Old Feb 23, 2012 | 09:33 PM
kejobe's Avatar
kejobe
I had to buy a new cap when I got my truck. I kept getting evap codes with it also, even though it was new. I took a little vacuum grease and coated the gasket and the edge of the filler neck where the gasket meets. Since I've done that (about 1 year ago) I havent had it come back. You could also use petrolium jelly (vasiline). Just smear a thin coat, no gobs.
Old Feb 24, 2012 | 10:01 PM
ZeroZero3's Avatar
ZeroZero3
That is a real good advice right there, thanks man, I will give it a try right after the on/off trick.
Old Feb 25, 2012 | 12:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Mar 1, 2012 | 02:41 PM
ZeroZero3's Avatar
ZeroZero3
On-Off trick is not working on my truck, I tried many times and my buddy too.
Old Mar 1, 2012 | 04:41 PM
zman17's Avatar
zman17
Try again. It should work on a 99. If not, maybe you have an early 99 late 98. This will be the first time I've seen it not work on a 99.
