PLENUM Done-Loss of pep????
Old Feb 24, 2012 | 11:35 AM
blackbeasst's Avatar
blackbeasst
Originally Posted by sniper dave
Yes, I had a local garage do it. I wanted to be armed with info before I go in there and put them on the spot and get a "this is normal until the new parts break in" routine. Or some other nonsense that they could try to get me outta there with.
I appreciate the responses.
Nice one Auggie....
just curious, how long did it take and how much did it set you back?
Old Feb 24, 2012 | 04:00 PM
gdstock's Avatar
gdstock
Nice one Auggie....
No, it is not normal. And since the plenum is not a moving part...."break in" should not be aprt of their discussion. I bet they jacked the firing order or fuel sync....just my guess....
Old Feb 24, 2012 | 06:44 PM
Magnum4406's Avatar
Magnum4406
I would make sure they set the fuel sync correctly. The position of the distributor controls injector timing.
Old Feb 24, 2012 | 09:38 PM
gdstock's Avatar
gdstock
+1 on fuel synch. If disty was moved, fuel synch is off.
Old Feb 25, 2012 | 06:20 PM
Wombat Ranger's Avatar
Wombat Ranger
If they disconnected the battery the PCM would need a bit of miles put on it to re-learn how to run the motor. If it still runs wrong after a hundred miles or two, start worrying.
