Custom rig build, engine selection.... Want your input
Old Feb 27, 2012 | 02:10 AM
99dodge318's Avatar
99dodge318
I would stroke the little 318, I've heard it revs up faster than a 408 plus a 390 just sounds meaner!
Old Feb 27, 2012 | 02:02 PM
Wombat Ranger's Avatar
Wombat Ranger
Originally Posted by Hahns5.2
You will need a different tranny with a V10.
What you really need first is some 4.56 gears.
Originally Posted by BackwoodsRam
The input shaft in the NV 4500 is different for a v8 and a v10
Remember the v10 and Cummins nv4500 has a different input shaft than a v8 4500
Look at his sig guys.
Old Feb 27, 2012 | 06:35 PM
Jason_Dodge's Avatar
Jason_Dodge
seams logical since he can't apparently use his NV4500 on the cummins.
Old Feb 27, 2012 | 06:41 PM
Hahns5.2's Avatar
Hahns5.2
If you can explain how he has an NV4500HD behind his 5.2, be my guest.
Old Feb 27, 2012 | 08:46 PM
BackwoodsRam's Avatar
BackwoodsRam
A custom flywheel that allows the mounting of a v10 out Cummins clutch and a360 bellhousing. But I very highly doing the OP has done this
Old Feb 27, 2012 | 09:03 PM
Wombat Ranger
Calling a company and 1) having them advise a V10/diesel disc that will match a V8 pressure plate, or 2) having a clutch custom built for his application.
Or what backwoods said....
Or drilling a v8 flywheel for the v10/diesel pattern.
Old Feb 27, 2012 | 09:23 PM
I would think all you would really need is the V-10/Diesel clutch, that isn't too large to fit into the V-8 pressure plate..... which really wouldn't surprise me if you could use all stock pieces, and make it work. Would have to do something about the pilot bushing though...
Old Feb 27, 2012 | 09:29 PM
Wombat Ranger
Pilot tip is the same diameter for both inputs.
That's what I meant by finding a disc to match the pressure plate. Just to make sure the friction surfaces line up.
