transmission overheating but fluid is good
Old Feb 28, 2012 | 09:54 AM
Navarro215's Avatar
Navarro215
Default transmission overheating but fluid is good
This morning I was driving my truck to work and about 15 minutes into the drive my overdrive shut off and the Trans temp light came on. I checked the fluid and it was still at the right level. My ujoints on the drive shaft are going bad, could the vibrations from that be putting stress on the transmission?
I have a 99 1500 4X4 with a 5.9
Old Feb 28, 2012 | 10:17 AM
xjarhead69's Avatar
xjarhead69
What makes you think its overheating?
Did fluid smell burnt?
Dave
Old Feb 28, 2012 | 10:24 AM
More likely the check valve in the cooler line is clogging up.
Old Feb 28, 2012 | 11:09 AM
Navarro215's Avatar
Navarro215
Thanks for the reply. I didn't smell anything and was just going off the light and o/d shutting off. I'll check to see if it was that valve.
Old Feb 28, 2012 | 01:36 PM
UnregisteredUser's Avatar
UnregisteredUser
Since it got hot enough to turn on the Trans Temp light, it's time to change out the ATF. It's cooked. Might as well do the check valve delete at the same time.
