can computors interchange
Old Feb 29, 2012 | 03:41 PM
95 lifted ram's Avatar
95 lifted ram
Default can computors interchange
I have a 95 ram 1500 5.9 and i believe the computor is bad, im in the process of figuring out because the gel like stuff on the inside is cracked. i was wondering if i pulled a computor off of a 94 dodge ram 2500 5.9 and the numbers didnt match on the computors would it work?
Old Feb 29, 2012 | 03:43 PM
So long as the computer is the same "tech level".... (OBDI) and for the same size engine, and same type of trans, (manual, or auto) it should at least run the engine and trans. Might get an ABS light.......
Old Feb 29, 2012 | 03:47 PM
95 lifted ram
it is auto, engines the same size and computor looks the same, connectors the same and its an obd1
Old Feb 29, 2012 | 03:50 PM
Should plug right in, and work just fine.
Old Feb 29, 2012 | 03:52 PM
95 lifted ram
alright thanks for the help hope this was my only problem
Old Feb 29, 2012 | 03:56 PM
Let us know.
Old Feb 29, 2012 | 09:46 PM
Hahns5.2's Avatar
Hahns5.2
94-95 should be the same.
Old Mar 1, 2012 | 01:33 PM
95 lifted ram
would you say my computer is bad if it sends 2 to 3 volts to all the sensors then randomly it sends 8 to 9 volts to the sensors
Old Mar 1, 2012 | 01:52 PM
I would check all the connections/grounds for the PCM, and see if that didn't straighten it out. If not, swapping it out as a test wouldn't be bad.
The battery IS fully charged, right?
Old Mar 1, 2012 | 02:41 PM
95 lifted ram
yes the battery is fully charged and the power and grounds are good
