2000 1500 Sport Only Stays Running when Given Gas?
Old Mar 1, 2012 | 03:28 PM
Rod Hardshaft's Avatar
Rod Hardshaft
Default 2000 1500 Sport Only Stays Running when Given Gas?
Hi there, I have a 2000 Ram 1500 Sport 5.9L truck, and it has been driving fine for ever. But one day, I try to start it, and it won't start. The only way it will start, is if you give it a little bit of gas, and if you let off the gas, it dies out. It doesn't shake or do anything I guess that it shouldn't seem to be doing. Anyone know what this could be?
Old Mar 1, 2012 | 03:29 PM
Bad Throttle position sensor, or sticking IAC valve. Clean the throttle body first, see if that doesn't help. Do we have a DIY for this in the FAQ Section???
Old Mar 1, 2012 | 03:33 PM
mantisman51's Avatar
mantisman51
https://dodgeforum.com/forum/2nd-gen...x.html#1059605
Old Mar 1, 2012 | 04:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yes, in the Van section. https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Old Mar 1, 2012 | 07:41 PM
If only we could pull the doghouse, and have easy access....
Old Mar 1, 2012 | 10:58 PM
redheadhunter21's Avatar
redheadhunter21
Did the battery die?.....I so it can take a little while for it to idle on its own
