problems since plenum fix
oh ok...I know when I had my chevy if you had lets say a code for a miss or o2 etx&you cleared it ,in about 30 miles it would pop back up.So that being said...heres my update.So no leaks valve cover looks like a wee bit of oil is trying to make it out so Ill address that asap.Well I had unplugged the egr solenoid when I did everything &then I had the shaking so...even though I did the egr delete I plugged it back in un did the batt for the reset pulled the pre cat 02 sensor as I was saying when I got that woosh...changed plugs&wires&now Ive drove about 200 miles&havent had nomore issues.So next Im gonna cut into my cat gut it&weld it back up&started shopping for someone who will run true duals &then finally put my lift&leveling kit&new wheels&tires spray it&do the gears&hope she appreciates it!I talked to a fella who owns a small shop&he told me give him 100 bucks&he will teach me how to swap my gears&we will do it together!So that works for me.Thanks for each&everyone of your guys help.
