problems since plenum fix
Old Mar 7, 2012 | 12:29 PM
  #71
zman17's Avatar
zman17
Retired Moderator - RIP
Well how about replacing it? Then we'll all know for sure I guess.
Old Mar 7, 2012 | 06:14 PM
  #72
cutthroatxxx's Avatar
cutthroatxxx
Well I was gonna do that...but now today Ive drove 80+ miles&no code has came back on&it hasnt don itso...idk???
Old Mar 7, 2012 | 06:32 PM
  #73
Augiedoggy's Avatar
Augiedoggy
I have a rebuilt transmission with like 200 miles on it... and a misfire issue that when the torque converter locks up causes the whole truck to shudder violently like its gonna shake itself apart... when I hit the overdrive button I know its working because I can see my rpms then jump back up and then the shaking almost completly goes away.... you might want to try doing the same thing to troubleshoot whether is a misfire or a transmission issue... trnasmission error codes do not turn the check engine light on and misfires do not always throw codes so...
Old Mar 7, 2012 | 09:55 PM
  #74
cutthroatxxx
Question...I took the ore cat 02 sensor off&when I did I heard a woosh or pop like it was air tight maybe? Thoughts?
Old Mar 7, 2012 | 10:14 PM
  #75
clogged cat?
Old Mar 7, 2012 | 11:20 PM
  #76
cutthroatxxx
clogged cat?
Thats what Im guessing,I pulled #8 plug&it had more build up on it than others.
&the guy I got it from said the plugs &wires not too long ago but from what I see it dosnt look like it.So Im gonna swap everything out.Cap ,rotor,wires...but I noticed on some of my plug wires those suckers wont come off no matter how hard I pull
Old Mar 8, 2012 | 08:37 AM
  #77
Get a pair of plug wire pliers. Twist the boot to get 'em to break loose, and then pull. Works every time, and doesn't trash wires.
Old Mar 8, 2012 | 02:08 PM
  #78
zman17's Avatar
zman17
Originally Posted by heyyou
clogged cat?
yup!....
Old Mar 8, 2012 | 04:57 PM
  #79
cutthroatxxx
Just bought new plugs&wires&the plug tool.Gonna put em in tomorrow &gut the cat.Quick question if I clear the codes how long does it take to throw em again like 30?
Old Mar 9, 2012 | 02:27 PM
  #80
zman17's Avatar
zman17
Codes can come up in any time frame. There is no set time.
