transmission issue...yay.
Old Mar 3, 2012 | 10:17 PM
wjxavier's Avatar
wjxavier
Default transmission issue...yay.
Well fellas, i'm back after a LONG period of not being on here haha. just got a couple issues i need some opinions on.
my tranny is having some issues. first one is when i go to slow down, my truck will not down shift from 3rd to 2nd unless i almost come to a complete stop. and when i go to hit the gas, it wont downshift and whines like crazy. i have to manually down shift it.
2nd issue: my transmission overdrive off feature wont work. light doesnt come on or anything when i push the button, and its a new dash switch.
i'm thinking maybe trans o/d solenoid? any help is appreciated, thanks fellas!
Old Mar 3, 2012 | 10:26 PM
gdstock's Avatar
gdstock
Maybe it's evil (from your sig!)
Strange symptoms for sure. Maybe OD but also may be TC not unlocking. Maybe start by checking TV cable, and if it is OK may need to drop pan and check solenoids and wiring.
Old Mar 3, 2012 | 10:33 PM
wjxavier's Avatar
wjxavier
TV cable is properly adjusted. i made sure of that first thing.
you're definitely right though, its evil. haha.
and thats actually my next question, i planned on dropping the pan and checking everything, but i'm not putting a stock pan back on again. i want to be able to regularly change fluid without dropping the pan everytime. and i want to be able to put a temp sensor in it as well. anyone know of any good pans that are decently priced? and where i can find them? i've only been able to find one on summit, and its a good pan, but they want $150...idk if i'm ready to fork that over just yet. i'd be happy with just a pan that has a drain plug haha.
Old Mar 3, 2012 | 10:42 PM
gdstock's Avatar
gdstock
You can add a drain plug to yours. Check your local auto parts store or rockauto.com.
I bought a Derale deep pan from a member here and love it. Has extra capacity and cooling tubes in bottom, and a port for tem sensor. $150 is probably not a bad prcie for an aftermarket deep pan.
Old Mar 3, 2012 | 11:47 PM
Johnny2Bad's Avatar
Johnny2Bad
The Derale is a nice pan, but you can get ones for less than $150. The B&M is about $130 and I've seen others for less. A lot of aftermarket pans for these trannys seem to go for the wrong side of $200 though.
Old Mar 4, 2012 | 12:25 AM
gdstock's Avatar
gdstock
A process that requires welding or the cast aluminum will increase cost. Stock pan with drain plug is the economy way to go and will work well.
Tha addition of a trans oil cooler is a pretty good investment. High heat = tranny failure!
Old Mar 4, 2012 | 11:09 AM
xjarhead69's Avatar
xjarhead69
Here you go http://www.transmissionpartsusa.com/...ans_s/9171.htm
For 154.84 you get Derale pan, the extension, filter and gasket.
That’s a great deal.
Dave
Old Mar 4, 2012 | 12:34 PM
Augiedoggy's Avatar
Augiedoggy
mine started behaving that way when the torque converter started to fail... eventually it would stall at stops.
Old Mar 5, 2012 | 08:26 AM
wjxavier's Avatar
wjxavier
I already have a tranny cooler put that in when I swapped the tranny. I think I'm just gonna drill a hole and put in a bung for a plug. It'll work.
