Cruise control problems
Old 03-13-2012, 08:17 PM
IHfarmer3339's Avatar
IHfarmer3339
IHfarmer3339 is offline
Default Cruise control problems
I have a 1997 1500 and the other day I went to use the Cruise control and it turned on but it didn't engage. Does any one have any idea what is wrong?
Old 03-13-2012, 08:19 PM
P1NKST@FF's Avatar
P1NKST@FF
P1NKST@FF is offline
Have you checked the cable to the throttle body? Haven't had an issue with my dodge but I've had the cable come undone on my mustang, cheap ford parts
Old 03-13-2012, 08:22 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,276 Likes on 3,023 Posts
Make sure the vacuum line hasn't dry rotted, and broken as well.
Old 03-13-2012, 08:28 PM
Matt Nickerson's Avatar
Matt Nickerson
Matt Nickerson is offline
Like HeyYou said, check the line..Battery acid can corrode the lines and cause the a/c and cruise to malfunction.
If you turn on your a/c and accelerate hard/drive up a hill, and the a/c switches to defrost (blows out defrost vents instead of out the normal ones) then check this out as well as the TSB: http://autorepair.about.com/library/faqs/bl073h.htm
Old 03-13-2012, 08:32 PM
P1NKST@FF's Avatar
P1NKST@FF
I need to check my vacuum lines user that tray cuz I have th af issues but not my cruise control works
Old 03-13-2012, 08:35 PM
IHfarmer3339
I know that none of my lines are corroded because I had my whole and I mean the whole truck torn apart.But I will look tomorrow afternoon.
Old 03-13-2012, 10:17 PM
gdstock's Avatar
gdstock
gdstock is offline
The plastic line gets brittle. Follow it around to the passenger side of intake and check ther also.
Old 03-14-2012, 11:33 PM
jswain's Avatar
jswain
jswain is offline
Also the cruise control servo, or whatever its called, little canister under the battery tray, can get battery acid dripped on it and leak, not hold vacuum. I had to replace mine with one from a junk yard to get my cruise working.
Old 03-19-2012, 02:37 PM
IHfarmer3339
I checked all the hoses under the hood and they are all in tact.
Old 03-19-2012, 02:43 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
The line you are looking for is under the battery tray, not just the lines under the hood.
Quick Reply: Cruise control problems
