Summit = pacesetter shorties?
Old Mar 18, 2012 | 03:52 PM
  #21
Augiedoggy's Avatar
Augiedoggy
Originally Posted by Ugly1
The Pacesetter longtubes? Not to say they shouldn't be used just that you need to match them to the system they are being put in to approach/equal well matched shorty performance and don't expect those kind of numbers unless you are pushing a $#1+ ton more air than stock and can really pressurize them so velocity stays high enough to get those bad boys really scavenging in a noticeable way.
I was just repeating what I have read.... reguler shorties are supposed to provide 7-14hp depending on other mods although many say its no where near that much.. and longtubes are suposed to be twice as benificial as the shorties.. but again I dont remember what this was based off of... data and facts or opinion and conjecture so....
Old Mar 18, 2012 | 03:55 PM
  #22
SyKo450's Avatar
SyKo450
Originally Posted by Augiedoggy
they are the same yes...some older style headers have a port for the egr but not the ones on ebay... thats why the fit chart shows them all to be the same thing..
Same eBay seller has some listed for $108 + $39 shipping
Old Mar 18, 2012 | 06:05 PM
  #23
Johnny2Bad's Avatar
Johnny2Bad
Originally Posted by P1NKST@FF
Is there any point in getting long tubes in our trucks? I want to get a set because I need more torque and kinda as an excuse to get true duals and get rid of the 1 in 2 out that I paid too much for...
There is a point but the longtubes I've seen for these trucks are all 1 3/4 primaries while the shorties are all 1 1/2" . That makes them very different animals with different goals, the difference is not simply primary tube length. Most exhaust math or software jumps in 0.125 increments, not 0.250, because a quarter inch diameter is a fairly steep jump as far as how the exhaust affects breathing and especially powerband.
V-8 engines are not particularly sensitive to primary tube length ... as long as they are a certain minimum and not too long, but primaries that vary over a range of 12~18" there is not much evidence you need to worry about it.
The firing order and crank degrees between firing pulses on a V8 plus exhaust ports being on two sides of the motor mean equal length primaries for pairing of cylinders to help scavenging isn't really possible. That's a big deal with 4-cylinder engines especially and can work on a (inline) 6, for street performance. On a race motor you go 4-1 anyway, which is what works on a V-8 as well.
All engines are sensitive to collector length and configuration though; something that isn't an issue with shorties designed to mate to stock exhaust. Long tubes will by their nature require you to fab something there, so you may as well discover what works while you're at it.
It might be worthwhile to explore that with the usual shorties instead of using the stock pipes. Fabrication and welding involved, and let us know how it works out since nobody has done it on an OEM Magnum vehicle as far as I know. May not be worth it with shorties but you never know. Some OEMs do pay special attention to the secondary pipe length and make them equal length on V-engines between the header collector and the cat.
They have a term for it that escapes me now but it's something like "quasi-dual exhaust"; in essence they are equal length duals from the collector up to the 2-1 at the single cat. I read an SAE paper on it once where one of the Japanese OEMs showed torque and powerband improvements on a V-6 engine configured that way versus the unequal length secondaries common on more mundane cars and trucks.
Basically on the Ram you would lengthen the passenger side secondary to equal the drivers side, which you could leave alone. The Japanese OEM just used two u-bends instead of going right from the collector to the cat on the passenger side, so it didn't really take up any more space, just a bit of height clearance required over the straighter pipe.
A set of 1 1/2 longtubes might prove better at torque improvement over the same diameter 1 1/2" shorties but there are none as far as I know for these engines so it's moot. (If you find some, post back because i'd be interested. A 1 5/8 might be better still, either as shorties or long tubes, since that should still preserve bottom end torque on a 5-ish litre engine but we don't know for sure; they don't seem to exist either).
The 1 3/4 longtubes will benefit if you are looking for higher RPM power improvements. Other engine mods would be recommended, and power down low will probably suffer. All in all for most of us the 1 1/2 shorties are a pretty decent compromise that offer some power benefits without turning our working trucks into un-streetable cars.
I built an exhaust designing database many years ago but the SW it runs inside no longer works on a modern OS. Maybe if I get time (yeah, right) I will put the equations into a modern app and punch in the numbers for the Magnum some day. But after running hundreds of simulations through that years ago, I would be shocked if 1 1/2 or 1 5/8 wasn't the way to go with these engines. The shorties might be a little short but not by much, and I suspect you wouldn't find a lot of power if you went longer at the RPMs we use the motor for daily. There might be some torque to pull with longer tubes. Maybe.
Old Mar 18, 2012 | 08:04 PM
  #24
Augiedoggy's Avatar
Augiedoggy
Isnt that what I already stated??
? there's a few older auctions of his that haven't ended yet but it looks like hes raising his prices by 80 bucks because they were all 108 before.
Old Mar 18, 2012 | 08:10 PM
  #25
Augiedoggy's Avatar
Augiedoggy
dont buy the ones from the other sellers.... I have compared flange plate to the other ones pictured and they are in fact cut totally different.. you will have to do trimming to get hem to clear the plugs
Old Mar 18, 2012 | 09:16 PM
  #26
SyKo450's Avatar
SyKo450
So I Think I'll give these a try, $150 for headers isn't TOO bad
Now I wonder if they're CARB exempt...................
Old Mar 18, 2012 | 09:28 PM
  #27
Augiedoggy's Avatar
Augiedoggy
actually its dirt cheap for stainless steel headers...
Old Mar 18, 2012 | 09:41 PM
  #28
SyKo450's Avatar
SyKo450
Are the gaskets and bolts it comes with good enough or do I need those Stage 8 fasteners and remflex gaskets?
Old Mar 18, 2012 | 10:01 PM
  #29
Augiedoggy's Avatar
Augiedoggy
gaskets are great but the bolts are the wrong ones,,, you want 1" grade 5 or 8 5/16-18 bolts...tell the seller you heard the bolts were wrong from here (point him here so he ca see others have verified it) and he might cut you a deal.
Old Mar 18, 2012 | 10:13 PM
  #30
SyKo450's Avatar
SyKo450
Good thinking
