well.... not to be a dick(sorry Z, haha) but if you cant figure out on your own what tools you need, by basic trial and error(running back and forth between your truck, and toolbox) til you get it right, than i think you need to bring the truck to a mechanic that knows what theyre doing.
on a side note..... lug nuts are 3/4(or 19mm) caliper slide pins are 9/16(or 14mm), and caliper bracket bolts are 13/16(or 21mm).....
good luck!
Your wrong about your sizes ( what a surprise) I don't need any of your advice. Why don't you just answer the questions and save your Caliper Pin is a Hex 3/8 genius
if you had posted what your truck was in the first place maybe someone could have helped you more directly, rather than taking guesses, or going off what their truck is. i wasnt wrong about sizes, im correct about them, for a 4x4. your telling a guy with over 1200 posts that your suprised about him getting something wrong. listen here nOob...... you have 7 posts, dont go around thinking youre all high and mighty, just because you couldnt figure out what tools to use and had to ask the internet. like i said previously, if you have to ask what size tools to use on YOUR truck, then maybe you shouldnt be working on your truck.
