Brake Fluid Consumption
Old Mar 19, 2012 | 11:43 AM
Dariel Bonilla's Avatar
Dariel Bonilla
Default Brake Fluid Consumption
I am having issues with my breaks. I was driving and i was coming to the light and when i pressed the brakes, the break pedal went really low and the ABS and brake light turned on. I was still able to stop. When i got home the following morning, i checked the reservoir and it was really low. I added break fluid. I just checked this morning and the break fluid is almost all gone. I looked around the master cylinder and i did not notice any leaks. My neighbor told me to check the wheels, which i haven't done yet. What could be the cause of this problem? thank you.
Old Mar 19, 2012 | 11:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The "brake line" running along side the fuel tank is most likely blown. Very common issue. Do not drive it until you fix it. Or a front line will blow also and you'll have no brakes at all, and something like this may happen. Or a lot worse.
Old Mar 19, 2012 | 12:16 PM
Dariel Bonilla
I have drums in the back and disc in the front. I was looking along at the lines and i didn't it? you think that you can pin point it for me? thank you. If i take it to a shop about how much you think is going to cost me? thank you so much.
Old Mar 19, 2012 | 12:22 PM
zman17's Avatar
zman17
I already did pin point it for you, "the line running beside the fuel tank" . Sometimes the leak is hard to detect, and of course it could be a wheel cylinder (or something else for that matter). And I have no idea how much a shop would charge. As I do my own work and prices vary with location anyway. Look yourself first and find the leak. Has to be dripping somewhere.
Old Mar 19, 2012 | 12:30 PM
crazzywolfie's Avatar
crazzywolfie
i would guess it should cost no more than $200 at at shop unless more stuff starts breaking. most shops charge between $50-$100/h. new brake line should not cost more than $30. if nothing was to break like the wheel cylinder bleeder screws the job might be cheaper.
Old Mar 19, 2012 | 02:38 PM
gdstock's Avatar
gdstock
I would check along the frame by the fuel tank and also pull drums off and check wheel cylinders. Bad brakes equals bad stuff.....as zman's photo shows!
And someone could die.
