gears
Old Mar 30, 2012 | 08:56 AM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by muddy_ram
so i was talking to my friend about gearing and he dosnt get why i need any lighter he said that running lower gearing will get worse fuel economy
i run 3.55 with 33 inch tires and i feel like the trucks sluggish i think that i might get better fuel economy because i wont have to press the pedal as hard to get up to speed what do u guys thing
the gears work with the tire size.... 4.56 gears with 35" tires would use the same amount of gas as stock 3.55 gears and stock tires or 4.10 gears and your 33" tires... thats why the "Offroad edition" truck came with 33" tires and 4.10 gears...(at least I think they came with 33" tires?)
3.55 gears with 33" tires = using more gas depending on how you drive since your always using more pedal to try to compensate for lack of get up and go and constant downshifting of the tranny.
4.56 gears and 33" tire would use more gas than a stock setup unless your towing possibly..because you would have more power than stock transferred to the ground.
Old Mar 30, 2012 | 04:52 PM
muddy_ram's Avatar
muddy_ram
thanks that helped alot
i was just woundering for sure befor i go spend the money should i get the 4.56 or 4.88 i use my truck so far for work and home but play around with offroad alot
Old Mar 30, 2012 | 05:11 PM
Wombat Ranger's Avatar
Wombat Ranger
I would get 4.88's, since you say you are gonna go bigger. I plan on 4.88's in mine in the future.
Old Mar 30, 2012 | 05:28 PM
muddy_ram's Avatar
muddy_ram
well on these diffs i plan 35 i dont wanna go bigger lots of ppl say u can brake the diffs ahah go bigger after the d60 swap or w.e i find ahahah mog diffs would be cool lots of work
Old Mar 30, 2012 | 05:34 PM
Wombat Ranger
You might enjoy this. Courtesy of Wh1t3Nukle (he sent it to me).
http://img1.pirate4x4.com/forum/showthread.php?t=726018
Old Mar 30, 2012 | 05:42 PM
muddy_ram's Avatar
muddy_ram
I WANT ahahah
