transmission line connections
Old Mar 26, 2012 | 07:42 AM
redneck_ram's Avatar
redneck_ram
Default transmission line connections
hey guys, ever since i replaced my transmission in august of 2010 one of my transmission lines have been leaking at the connection on the transmission.
i think i stripped it out, do any of you guys know what the dealer part numbre is for both the transmission lines, and if the male connections on the trans, are replaceable?
thanks guys.
Old Mar 26, 2012 | 08:59 AM
Grab the 01 parts manual from the faq section here. More information than you will ever need there.
Old Mar 26, 2012 | 09:01 AM
redneck_ram
feel kinda retarded for not checking there first. i always check it for info first before i post.
Old Mar 26, 2012 | 09:56 AM
redneck_ram
well.... i searched, and searched, and searched through the 01 service manual, and couldnt come up with anything. either i overlooked it 3 times, or its just not there. so if anyone can tell me if the male connectors on the transmission, for the cooler lines are removable, and replacable, let me know! thanks
Old Mar 26, 2012 | 09:57 AM
Grab the PARTS manual. Not the service manual. (though you should have that as well. )
Old Mar 26, 2012 | 10:07 AM
redneck_ram
wow, feel even more retarded for reading your post wrong, guess these allergies are kicking my *** more than i first thought.
Old Mar 26, 2012 | 10:38 AM
redneck_ram
found it!
but.... there are zero part numbers for it, guess i get to go to the dealer today, as well as getting te part numbers for the cooler lines, which i think i found also, gonna google the numbers to make sure.
thanks heyyou!
Old Mar 26, 2012 | 10:51 AM
The list of numbers with the part numbers and such scrolls, is it just down a line or so?
Old Mar 26, 2012 | 11:10 AM
redneck_ram
well with a bit of google seaching i found the part number for the fitting, its 2-06033879, and the cooler lines are 52028671ad (pressure line), and 52028839aa (return)
glad i found them, now i can get rid of the annoying leak i have!
Old Mar 26, 2012 | 07:11 PM
dhvaughan's Avatar
dhvaughan
summit has them too. not that expensive.
http://www.summitracing.com/parts/RNB-624-304/
http://www.summitracing.com/parts/RNB-624-305/
