underdrive pulley set?
Old Mar 27, 2012 | 08:56 AM
Twisted Metal's Avatar
Twisted Metal
The underdrive pulleys are Bigger, not smaller. Most companies sell either a single crank underdrive pulley or as a pair, crank and alternator. You will need about a 95" serpentine belt if you run an underdrive crank pulley and standard alt. pulley. (this is the setup I have on my truck now). It is a PITA to find a belt to match up to use both underdrive pulleys. Its roughly a 97-98" belt needed to use the stock tensioner. I ran both on my truck initially, I wound up using different diameter tensioner pulleys to make it work.
I try to break it down with simple Yes or No
Yes- you will see considerable voltage drop at idle running both pulleys(about 10 volts at idle. Around 11 at idle with single crank underdrive)
Yes- The Voltage will come back up as you accelerate or raise idle.
Yes you may encounter cooling issues if you live in a hot climate. I live in NJ, my truck in summer heat and A/C on has never run over 200.
Yes- You may feel/see a difference after installing them. I noticed a 200 rpm drop at 70 mph on highway.
Yes- Installing the crank pulley on a 5.2 is as simple as remove bolt,removed stock,install new, tighten and retorque bolt. On a 5.9 you have the harmonic balancer to deal with.
No- This is not a "power adder" mod per say. But increased accessory life and the engine working less(read mpg).
No- If you constantly run alot of lights,winches,high powered stereo. This might now be the greatest mod for you. Especially if you do alot of stop and go driving.
Old Mar 27, 2012 | 03:08 PM
Wombat Ranger's Avatar
Wombat Ranger
^^ Okay to clarify: Underdrive crank pully will be smaller, any other underdrive pully will be larger.
Right??
