underdrive pulley set?
Old Mar 26, 2012 | 07:40 PM
sam_priem's Avatar
sam_priem
Default underdrive pulley set?
i've been hearing more and more about underdrive pulley kits and the performance gain from them. are they really worth the money? do they make a noticeable difference? has anybody had experience with these?
Old Mar 26, 2012 | 07:47 PM
Wombat Ranger's Avatar
Wombat Ranger
Well the science is solid... Gears would be a more noticeable gain
Old Mar 26, 2012 | 07:50 PM
redneck_ram's Avatar
redneck_ram
i have the hughes underdrive crank pulley, and i like it. there is a noticable throttle response change(for the better), and it seems to get up and go a bit better now. more low end torque so it seems.
Old Mar 26, 2012 | 07:54 PM
sam_priem's Avatar
sam_priem
an underdrive pulley set is also noticeably less expensive than gears lol
Old Mar 26, 2012 | 08:23 PM
sam_priem's Avatar
sam_priem
would i use the stock serpentine belt or do i need a shortened one?
Old Mar 26, 2012 | 08:25 PM
Ham Bone's Avatar
Ham Bone
What are these so called "under drive pulleys" anyway
Old Mar 26, 2012 | 08:30 PM
Wombat Ranger
Smaller diameter pulley/s. Makes the belt turn slower, so the engine is doing less work. So more power is going out the backside of the motor instead of the front
Old Mar 26, 2012 | 10:54 PM
Hylander7's Avatar
Hylander7
How will this effect cooling and Charging, seeing how the water pump and alternator will be turning slower ?
Old Mar 26, 2012 | 11:20 PM
Volt gauge may get a little bit lower at idle, and thats about it. If you live in a hot climate, E-fans would be the ticket there, if it ever became a problem.
Old Mar 26, 2012 | 11:40 PM
Wombat Ranger
That's exactly what redneck_ram said about his.
