Pulling to the right
Old Mar 27, 2012 | 11:35 PM
Joey Buentello's Avatar
Joey Buentello
Default Pulling to the right
Just a little when I brake. Did rear drum shoes, front pads, still pulls a little to the right. Sticking caliper?
Old Mar 27, 2012 | 11:43 PM
Matt Nickerson's Avatar
Matt Nickerson
Make sure the rotors are clean, the brake slide pins are greased, and that the lines to the drivers side caliper is intact. Also check tie rods and other steering comp.
Old Mar 27, 2012 | 11:45 PM
gdstock's Avatar
gdstock
And it could be sticking caliper. Raise front end and spin wheel to see if it is free or dragging.
Old Mar 28, 2012 | 05:14 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Could also be the rear brakes. Did you adjust them properly?
Old Mar 28, 2012 | 05:20 PM
peshewa's Avatar
peshewa
Caliper slide pins are the usual suspect for this. I remove them, sand off any scale or rust if there is any & use the high temp grease on them & it usually cures it. I also have a habit of completely flushing all brake fluid when I do a regular brake job anyway - it removes the spongy feeling since the brake fluid naturally absorbs moisture anyway & the flush cures that.
Old Mar 30, 2012 | 10:21 PM
Joey Buentello
Default cool
I'll check it out tomorrow.
