Overheating
Old Mar 28, 2012 | 11:36 PM
Matt Nickerson's Avatar
Matt Nickerson
Originally Posted by Purple5gear1500
...I changed the thermostat twice now and it still over heats... the water pump and rad are new...
He said the radiator and water pump and thermostat was already replaced.
Although it's possible there was a faulty replacement for any/all of those parts it's a little unlikely.
So to compress everything down...
-Burp the system
-Test/Check Fan Clutch
-Replace Rad. Cap (should've bought a new one when rad was replaced)
-Check lower rad hose to see if it collapses (and that it isn't HOT)
-Make sure coolant has correct ratio
-Check for blown head gasket <--probably the least likely one
Old Mar 29, 2012 | 12:31 AM
gdstock's Avatar
gdstock
I'm betting burp!
Old Mar 29, 2012 | 11:57 AM
91Dakota318's Avatar
91Dakota318
So i ran it on a hill and it started to run like crap, the upper rad hose is cold.. lower is hot
Old Mar 29, 2012 | 12:43 PM
gdstock's Avatar
gdstock
It took about 15 to 20 minutes running to get the air out of mine.
What made it run like crap?
Old Mar 29, 2012 | 01:14 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Whoa! It should be the opposite. You stated the water pump was new. Sounds like you have the wrong water-pump installed and it's running backwards (opposite flow of what these trucks flow).
Old Mar 29, 2012 | 01:43 PM
PapaG's Avatar
PapaG
Or if he somehow has the belt installed incorrectly it could possibly be making the WP pulley go in opposite direction...?
Old Mar 29, 2012 | 02:03 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Good catch. Yes, check the belt routing as well, and be sure to drink your Ovaltine.
http://www.youtube.com/watch?v=zdA__2tKoIU
Old Mar 29, 2012 | 02:16 PM
gdstock's Avatar
gdstock
Never thought about belt routing, but that is definitely one explanation for the symptoms.
+1 on double checking that!
Old Mar 29, 2012 | 02:44 PM
redneck_ram's Avatar
redneck_ram
did you guys realize it was 2 different posters, with the same problem? this guy that parked on the hill never told us what his problem was.....
Old Mar 29, 2012 | 06:18 PM
gdstock's Avatar
gdstock
Crap. I missed that....Maybe the belt is on the wrong truck!
