Whats wrong with my truck???
Old Apr 10, 2012 | 12:59 PM
  #31
moss500berg's Avatar
moss500berg
BWD i think, got it from advance auto parts.
Old Apr 10, 2012 | 01:23 PM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
Not the best choice, but not the worst either. If you still have the receipt return it under warranty. And make sure you disconnect the negative battery cable before replacing it. As a matter of fact, maybe try resetting the PCM now. Never know, might help.
Old Apr 10, 2012 | 01:34 PM
  #33
moss500berg
That just involves removing the negative cable right? Havent done it with the sole intent of resetting the pcm.
Old Apr 10, 2012 | 01:38 PM
  #34
LoneWolfArcher's Avatar
LoneWolfArcher
Cut the cat out, put in a straight pipe and be done with it. (Just for HeyYou and VW!)
Old Apr 10, 2012 | 01:44 PM
  #35
zman17's Avatar
zman17
Correct. It will reset while you clean or replace the part. If you just want to reset the PCM, disconnect the negative cable and turn on your headlights for a few seconds. Then turn them off and reconnect battery cable.
Old Apr 10, 2012 | 03:08 PM
  #36
Augiedoggy's Avatar
Augiedoggy
they are a bitch to remove... I did mine a few weeks ago...you have to wiggle it past the rubber grommet and it does pull right out.... (mine didnt fix my misfire at the time btw) they are only $22 shipped from ebay BTW... advance wanted like $45 I think..
and resetting the PCM will do nothing for replacing the CPS....
Old Apr 10, 2012 | 03:09 PM
  #37
moss500berg
Alright thanks zman.
@lonewolf: i would if i had the money, id have long tubes and a full exhaust by now, i didnt realize i had a o2 sim on my truck already, thats what has been holding me back. Right now my exhaust is stock manifolds, stock y-pipe/cat with the factory piping up to the first hangar (the one incorporated in the trans crossmember) after that theres nothing lol
Old Apr 10, 2012 | 03:12 PM
  #38
moss500berg
The first time i did it wasnt so bad, its only been in there for 3-4k miles, So it should be fairly easy
Old Apr 10, 2012 | 03:39 PM
  #39
Silverdodge2001's Avatar
Silverdodge2001
Alrighty problem has been resolved by replacing the crankposition sensor. Thanks to everyone for your help and infinite wisdom.
Old Apr 10, 2012 | 04:11 PM
  #40
A_POLVADO's Avatar
A_POLVADO
Unhappy
Originally Posted by zman17
Duh, I forgot to post the link. Thanks bud. After all , all I do is troll for posts that are in the wrong section. LOL
Hey I said I was sorry It will never happen again
