Speedometer probs
Old 03-31-2012, 10:54 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,396 Likes on 3,136 Posts
Put the rear up on jackstands, put it in drive, and back probe C1 pin 8 at the PCM, and see what you are getting. BE CAREFUL. Have a friend to help..... (safer that way.)
Old 04-01-2012, 01:02 PM
Augiedoggy's Avatar
Augiedoggy
Augiedoggy is offline
I would hook it up to a scanner that displays the speed the pcm thinks your doing... that way you can determine if your failure is before or after the pcm...
A $20 elm327 adapter from ebay and an/ or Bluetooth phone or laptop can be used if you dont have any type of scanner now... I use one with my android phone and an app called "torque"...
Old 04-01-2012, 01:07 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Try this for S's & G's and see what if anything comes up. https://dodgeforum.com/forum/2nd-gen...code-list.html
Old 04-02-2012, 09:19 AM
johnnyrocket5363's Avatar
johnnyrocket5363
johnnyrocket5363 is offline
I have a scanner that displays live data. It spits out a code P0500 and the scanner feedback says the truck is not moving. Can someone tell me which is c1, pin 8? I'm fixing to jack it up..
Old 04-02-2012, 09:39 AM
johnnyrocket5363
If (heaven forbid) it is my PCM going bad, whats the difference between a bad flash and bad PCM? And can any PCM get re-flashed to my truck?
Old 04-02-2012, 09:41 AM
HeyYou is offline
Connector 1 is on the right side, if you are standing in front of the truck, facing the PCM.
Pin 1 is in a corner, and is probably empty on yours. (coil driver for V-10) Pin 8 will be in the same row, Gray with Black trace.
Old 04-02-2012, 11:10 AM
johnnyrocket5363
Okay, here are my findings.
Engine off, ignition off: no voltage, 8 ohms resistance.
Turned on: no resistance, .5 volts
Would not crank while probed
Removed probe, cranked, 5th gear, idling
Probed, almost no resistance, engine died.
Old 04-02-2012, 11:43 AM
HeyYou is offline
Gah, I KNOW the 'correct' values are somewhere in the service manual, for, for the life of me, I don't seem to be able to come up with them at the moment.
Old 04-02-2012, 12:53 PM
johnnyrocket5363
I looked at the service manual, no specs....
However, the grey/black wire is the speedometer driver, correct?
Wouldn't I need to try the speed signal, the white/orange wire?
Old 04-02-2012, 03:45 PM
johnnyrocket5363
Current findings:
In first gear, plugged voltmeter into RWAL sensor, no deviation in resistance. Had a friend turn the tire very slowly to check again, still nothing. Showing wery little resistance. Thoughts?
Quick Reply: Speedometer probs
