transmission ignition problems...
Old Apr 5, 2012 | 09:17 PM
blackoutdodge's Avatar
blackoutdodge
Exclamation transmission ignition problems...
i put new od unit on today. got everything hooked up right... but now it wont start turn over click nothing... at all.. and abs light comes on air bag lights come on andcheck gauges.. also the shifted wont budge from park at all and nothing is bound up from cab to transmission.. im so lost.
Old Apr 5, 2012 | 09:19 PM
Did you pull the trans out to do the O/D unit?
Old Apr 5, 2012 | 09:21 PM
blackoutdodge
nope. just od unit
Old Apr 5, 2012 | 09:23 PM
Disconnect the shift linkage from the trans, and see if the lever on the column will move, if it does, try the lever on the trans..... I suspect you don't have the park linkage inside the trans hooked up properly.
Starting I think is a separate issue.
Old Apr 5, 2012 | 09:25 PM
blackoutdodge
i never un hooked it.. ? how would it be messed up
Old Apr 5, 2012 | 09:26 PM
blackoutdodge
i dont understand what happened it started fine last week too.
It's internal to the trans, and I think, but, not 100% sure, that it extends into the O/D unit....... Might wanna look in the manual at how it is supposed to work, and take it from there.
Old Apr 5, 2012 | 09:29 PM
blackoutdodge
it dont extend into od unit. only thing that went into od unit was the shaft and the pipe that puts fluid back there. maybe its time for a chevy.. good god what has this world come to
Old Apr 5, 2012 | 09:35 PM
Check and see if the park linkage is jammed up in the trans. Disconnect the shift lever, and see if you can move the lever on the trans. (block the wheels first.....) If the trans shifts ok, check the column shifter. God only knows what happened during the swap.
Old Apr 5, 2012 | 09:42 PM
blackoutdodge
yea thats the plan for tomorrow.. i just dont know how this happened
