Midway Through Plenum Repair
Old Apr 6, 2012 | 12:51 PM
Ham Bone's Avatar
Ham Bone
Default Midway Through Plenum Repair
Ive got the intake and belly off, about to clean the intake and cut the runners. I'm also gonna mod the throttle body while it out.
So far I've only broken the coolant temp sensor, everything else has gimme according to plan.
When I pulled the fuel rails two injectors popped off the rail, I got them out of the intake. They look like they just pop back into the rail. Please tell me this is the case. New injectors are expensive.
The gasket for the plenum plate was competlely gone, only a few little spots remained of old clumped gasket.
Here's some pics
Old Apr 6, 2012 | 01:10 PM
PETE_YK's Avatar
PETE_YK
Yours looks preeeeetty greasy i must say lol How long have you been running it like that? God knows how sludgy mine will be when i get around to it haha.
Old Apr 6, 2012 | 01:13 PM
Ham Bone's Avatar
Ham Bone
200,000 miles on the ole 360. It's pretty bad. Who knows when the gasket went.
Doing timing chain also
Old Apr 6, 2012 | 01:26 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Yes, the injectors just pop in place -- *HOWEVER*, you would be wise to replace all 16 o-rings (upper and lower) lest you risk a leak due to a torn o-ring. They are very, very cheap insurance to prevent aforementioned leakage and a possible engine fire. Install them by lightly coating with oil and rolling them onto the injector. Then, install the injector into the intake before finally installing the fuel rail. Again, lubricate before installation or they'll tear.
Old Apr 6, 2012 | 01:33 PM
dhvaughan's Avatar
dhvaughan
injectors do just pop in/out with O-rings. i'd replace all the o-rings. you should be able to get a complete set for not too expensive. lube them with a light coat of vasilene.
parts search at autozone, advance, oreillys turns up only this felpro set of 4.
i don't know if you need 8 or 16? somebody help me out. (VW beat me to it)
http://www.oreillyauto.com/site/c/de...2524&ppt=C0024
Old Apr 6, 2012 | 01:36 PM
Ham Bone's Avatar
Ham Bone
Thanks, and tips on cleaning this sucker?
Old Apr 6, 2012 | 01:39 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Easy Off oven cleaner. And no, I'm not joking.
Old Apr 6, 2012 | 01:46 PM
Ham Bone's Avatar
Ham Bone
I actually found a place to get it dipped.
Old Apr 6, 2012 | 01:53 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Even better. If you could get it media blasted afterward that would be the icing on the cake.
Old Apr 6, 2012 | 01:59 PM
Ham Bone's Avatar
Ham Bone
Is there anything special to clean the injectors while they're out. Carb cleaner?
