Problems starting
Old Apr 9, 2012 | 02:50 PM
byronpen's Avatar
byronpen
Default Problems starting
OK my truck has a very hard time starting this just started over night, it turns over and over then if it dose start the hole truck shakes. I replace the ignition coil. and the fuel pump is working. plenum replaced.
Other times it just starts right up.
Ideas
Old Apr 9, 2012 | 02:56 PM
Fuel pressure?
Old Apr 9, 2012 | 02:58 PM
byronpen's Avatar
byronpen
best way to test
Old Apr 9, 2012 | 03:01 PM
With a gauge. Should be able to rent one at the parts store... of course, you need to test when it is being hard to start.
Old Apr 9, 2012 | 03:04 PM
byronpen's Avatar
byronpen
could fuel filter be clogged?
Old Apr 9, 2012 | 03:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Try turning the key on and off 4 or 5 times first (without starting). Then see if it starts. And does it do this after sitting overnite or anytime? (like even after it's started the first time)
Old Apr 9, 2012 | 03:31 PM
peshewa's Avatar
peshewa
I would suspect a cracked distributor cap. Mine did EXACTLY what yours is doing, mostly in the morning when it was more humid with a dew covered truck. I replaced the distributor & rotor cap together & the problem is now gone.
Old Apr 9, 2012 | 03:38 PM
zman17's Avatar
zman17
Good call, that's where I was going after I found out if it didn't start even after warm up. Then I was going to move on to the ECT sensor.
Old Apr 11, 2012 | 02:21 PM
byronpen's Avatar
byronpen
Replaced distributor cap and rotor, same problem. How can the ECT senor stop the truck form starting?
Old Apr 11, 2012 | 03:00 PM
zman17's Avatar
zman17
It is starting, just running crappy when it does. It's worth testing it at least. I'd also check the cat. Maybe pieces are moving around inside.
And you didn't answer post #6
