Transmissions!
Old Apr 9, 2012 | 09:21 PM
Bigyooper25's Avatar
Bigyooper25
Default Transmissions!
alright i am about to buy 2000 Dodge ram 2500 5.9 4x4. i know dodges have horrible transmissions, what should i do, rebuild the transmission? or drop a new one in? any help will be grateful. Thank you.
Old Apr 9, 2012 | 09:23 PM
What's wrong with the one currently in it? (aside from it being a weak assed dodge auto?)
Gas engine, right?
Old Apr 9, 2012 | 11:36 PM
johnnyjaws98's Avatar
johnnyjaws98
delet the check valve and do afilter change adjust the front and rear bands and get back to us
Old Apr 10, 2012 | 04:21 AM
UnregisteredUser's Avatar
UnregisteredUser
If you can afford it, buy and install a PATC Mega Viper and then stop thinking about it.
Old Apr 10, 2012 | 05:27 AM
Johnny2Bad's Avatar
Johnny2Bad
A transmission isn't broken until it's broken.
Although the Dodge OD transmissions do have a reputation, no company's overdrive transmission is as strong as the non-OD units they're derived from, and every OEM has higher rates of problems with OD units.
Do some preventative maintenance (as suggested above). If it doesn't have a transmission cooler, add one. Maybe add a trans temp gauge, and don't overheat it. Don't tow in OD. That's about it, I think. Run it.
Dodge tranny problems are common, but believe it or not some people don't have any problems.
If you haven't agreed to a price yet, whine about your fear of tranny issues and try to negotiate a lower price. Could actually make you money.
Old Apr 10, 2012 | 09:51 AM
Ohio Mossy Oak's Avatar
Ohio Mossy Oak
From: Born,raised and currently reside in eastern Ohio
That is what I did.
Old Apr 10, 2012 | 09:59 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Do this.
Old Apr 10, 2012 | 11:21 AM
zman17's Avatar
zman17
Retired Moderator - RIP
+1, but bring it to a shop you trust and let them do it(band adjustment). You can do the check valve delete yourself. Make sure they use ATF+4 only. Have them clean or replace the Governor sensor also. Have them replace with one of these if you replace it.
Also test drive for a good amount of time, and make sure it shifts correctly before you buy the truck. Do you know what the truck was used for in it's previous life? And how many miles on it?
Old Apr 10, 2012 | 01:29 PM
LoneWolfArcher's Avatar
LoneWolfArcher
I don't know why you would do anything above preventative maintenance before it actually goes. But that's just me.......
Old Apr 10, 2012 | 01:32 PM
P1NKST@FF's Avatar
P1NKST@FF
Buy it if Its good. I got 270K all original transmission, I think its on its 4th or 5th filter change, and only currently acts bad when its cold.
Oh its also pushing 35" tires with upwards of 400lbs of stuff in the bed....
