Loud whistling noise
Old Apr 11, 2012 | 01:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by dhvaughan
good idea. its a bit tricky to get it seated correctly.
there is also a gasket between the TB and air cleaner that tends to get lost or damaged. avail at all parts stores for $1-2.
on the idea of spraying chemicals around the engine bay and the idea that it gets sucked in - and somehow causes the engine to run faster or slower.... I've tried that a hundred times and NEVER gotten it to work.
i've tried carb cleaner, starting fluid, etc. all it's ever accomplished for me is to make a mess and waste time.
That's because you had no vac leak.
Old Apr 11, 2012 | 01:52 PM
master tech's Avatar
master tech
Site Moderator & Tech
Does your 1500 have a V10 engine? If ti does replace the intake manifold gasket.
Old Apr 11, 2012 | 03:53 PM
Yamahaboy125's Avatar
Yamahaboy125
No, it has the 5.2, intake manifold gaskets have been replaced not to long ago
Old Apr 11, 2012 | 04:23 PM
dlyter09's Avatar
dlyter09
Woah.... a 1500 with a v-10 engine????
Old Apr 11, 2012 | 05:00 PM
JackJ's Avatar
JackJ
Ram SRT10
Old Apr 11, 2012 | 05:24 PM
Ham Bone's Avatar
Ham Bone
Originally Posted by JackJ
Ram SRT10
Not second gen
Old Apr 11, 2012 | 05:48 PM
JackJ's Avatar
JackJ
Originally Posted by Ham Bone
Not second gen
Picky Picky
Old Apr 11, 2012 | 06:41 PM
Ham Bone's Avatar
Ham Bone
Picky Picky
You started it!!!
Old Apr 11, 2012 | 07:10 PM
dlyter09's Avatar
dlyter09
Lol I figured this is the 2nd gen section not the 3rd gen which is what had me confused
Old Apr 11, 2012 | 07:25 PM
JackJ's Avatar
JackJ
You started it!!!
I must admit I spent about 15 minutes trying to find someone who had done a V10 swap so I could be right, but then I got bored and started trying to find new themes for Ubuntu
