I heard an odd clicking noise.
Old Apr 10, 2012 | 08:55 PM
vengeancex's Avatar
vengeancex
Default I heard an odd clicking noise.
Long time no see, I recently discovered a noise going around inside of the engine itself.
I was putting some coolant in my rad and I keep hearing like a quiet noise. Sounds like a little piece of metal or something knocking back and forth on each side of the engine :|
I can't really confirm what it is, but it just sound slike something is knocking around inside the engine. Any clues?
Old Apr 10, 2012 | 09:00 PM
Ham Bone's Avatar
Ham Bone
Could be the lifters clicking, is your oil pressure and level okay?
Old Apr 10, 2012 | 09:03 PM
vengeancex's Avatar
vengeancex
Pressure and levels are all good.
I had my oil/filter changed about.. 1 month go. I have about 4.5k miles on it since. I recently added some more fluid, figuring the filter might be fine still.
Old Apr 10, 2012 | 09:06 PM
Ham Bone's Avatar
Ham Bone
Welp I'm out of ideas good luck!
Old Apr 10, 2012 | 09:12 PM
vengeancex's Avatar
vengeancex
What are the chances the lifters might be bad/loose
Old Apr 10, 2012 | 09:18 PM
Ham Bone's Avatar
Ham Bone
They lifters themselves should fine. If you have low oil pressure or low levels, they could be slightly dry. The noise you get is lifters hitting the cam and the valves
Old Apr 10, 2012 | 10:12 PM
lastrights's Avatar
lastrights
Maybe a exhaust leak
Old Apr 10, 2012 | 10:16 PM
Or maybe you are just hearing the injectors....
