........cams........
Old Apr 11, 2012 | 02:47 PM
johnnyjaws98's Avatar
johnnyjaws98
Default ........cams........
Have a 98 dodge ram 1500 4x4 318 going 2 do the timing chain this week with plenum fix and kegger mod + waterpump has any one put a cam in there 318 that gos in with out any mods to the pmc? looking for low and mid range and top an all around cam that would be better than stock just thinking while ill have it a part
Old Apr 11, 2012 | 03:23 PM
A_POLVADO's Avatar
A_POLVADO
In the diy section i cam across a good cam write up made me change my mind on doing a cam just gonna do the 1.7 hs rockers best bang for the buck for me.
Old Apr 11, 2012 | 06:44 PM
Ham Bone's Avatar
Ham Bone
Try to grab a double roller timing chain for it
Old Apr 11, 2012 | 11:48 PM
johnnyjaws98
Need more answers than that
Old Apr 12, 2012 | 09:13 AM
A_POLVADO's Avatar
A_POLVADO
THIS IS THE CAM HUGHES SAID I SHOULD RUN GOOD STREETABLE CAM (THEIR WORDS) HER0814AL or ALN
Old Apr 12, 2012 | 05:56 PM
johnnyjaws98
whaT MOTOR DO YOU HAVE?
Old Apr 12, 2012 | 06:43 PM
CPTAFW163's Avatar
CPTAFW163
Here is a good camshaft. It is called an "RV cam." You will gain gobs of torque and add horsepower.
http://stores.hi-potek.com/-strse-25...4x4/Detail.bok
Here is a writeup about a cam that has almost the exact specs and some dyno numbers:
http://www.bionicdodge.com/bionic/in...p?topic=9197.0
Old Apr 13, 2012 | 09:06 AM
A_POLVADO's Avatar
A_POLVADO
318 But i was planning for heads If you email hughes tell them what you have and are doing to it they will help you choose a cam
