Oil leaking down front of engine after plenum repair
Well I replaced the stock plenum with an aluminum unit and now I have oil leaking from somewhere in the front of the engine. I cant see exactly where it's coming from but it is running down both sides of the timing chain housing from somewhere above that I cannot see. I'm guessing the front manifold gasket isn't sealing right and the oil is coming from there?
Damn! Looks like I'm going back in? What a PITA!!!!
did you use silicon on the edges of the front intake seal? if not theres probly small gaps between the front seal and the 2 cyl heads where oil can seep through.
Did you follow directions in any form of a manual(free download or Haynes)? And cut some old bolts to help make lining up the intake a lot easier? As I know for sure is in the end all plenum thread?
Yeah I followed the direction I got on this forum including using the old bolts as guides. Although I now think I over torqued the bolts. I just tested my torque wrench and my buddy's and my bolts are torqued to
20-22 ft. lbs. Good thing is none of them broke off.
Mines doing it too but on the back side! tried a thick bead of RTV instead of the failed valley gasket and still leaks but not as bad. Did you fix your problem?
