Air conditioner problem!
Old Apr 15, 2012 | 04:28 PM
ryanw111182's Avatar
ryanw111182
Default Air conditioner problem!
Hey everybody,
My heater works fine, but my air conditioner keeps blowing hot air even when its turned to cold.
It also blows hot air through the vents when the fan is off and turned to cold.
Why does hot air come through the vents when everything is off???
Please advise!!!
Old Apr 15, 2012 | 05:22 PM
Wombat Ranger's Avatar
Wombat Ranger
If you are as dumb as me, you might own your truck for, say, 11 months before you figured out that the top vent selector **** also can be switched to the off position, pointing at 6 o'clock. I was so excited when I figured that out on friday haha.
This is if you have the early (94-97) style dash. I have no clue about the 98-01/02 dashes, as I don't own one.
As for the air conditioning blowing hot, check for leaks in the system and see if it needs a recharge.
Old Apr 15, 2012 | 05:23 PM
Does your a/c compressor engage?
Old Apr 15, 2012 | 06:58 PM
stewie01's Avatar
stewie01
What about the blend door? I used my A/C the first summer I had the truck then all of a sudden it would blow hot air, and will blow hot air even with all the control's off. Very annoying as it's just about summer already here in South Ga.
Old Apr 15, 2012 | 07:22 PM
ryanw111182
Thanks for the replys... I will check the blend door!
Old Apr 16, 2012 | 04:25 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Assuming it's a dodge ram , is there any possible chance we can have some info on it? Like what year it is at least? Add all the info about it to your sig and profile.
Old Apr 16, 2012 | 05:01 PM
gdstock's Avatar
gdstock
We are supposed to use ESP to figger' that out!
Old Apr 16, 2012 | 05:42 PM
zman17's Avatar
zman17
EDIT: Oh never mind!
Old Apr 17, 2012 | 01:48 PM
ryanw111182
Sorry guys.
It's a 2001 Dodge Ram 1500 short wide with a 5.2L V8..... :-)
Old Apr 17, 2012 | 03:42 PM
gdstock's Avatar
gdstock
You can put that info in your signature and it will show each time so everyone knows what you are working with. 2wd or 4wd?
Also, any result on blend door?
