'99 Ram wheels on '91 model 2wd?
Old Apr 18, 2012 | 10:54 PM
classicfins's Avatar
classicfins
Default '99 Ram wheels on '91 model 2wd?
Hey folks.. New to the forums, but I must say that this is one great resource! I have a '91 Dodge 2wd ext cab and I'm thinking of buying a set of 16" alloy wheels/tires from a '99 Ram 2wd. The bolt pattern is the same on both sets, 5 lug on 5.5 pattern, but I am concerned about the offset, brake clearance, etc.
My '91 has the factory steel 15" wheels, and I've attached a pic of the wheels I'm wanting to buy, and also a pic of a '91 model with the factory steel wheels like I have on mine. Are there any problems that will prevent these wheels from fitting correctly? I am worried that the later model wheels may set the tire too far inward? Thanks in advance,
Doug
Attached Thumbnails '99 Ram wheels on '91 model 2wd?-ram.jpg   '99 Ram wheels on '91 model 2wd?-oldram.jpg
Old Apr 18, 2012 | 11:14 PM
Wombat Ranger's Avatar
Wombat Ranger
Only one way to find out... Will the seller let you test fit one or two up front?
Old Apr 19, 2012 | 08:46 AM
classicfins
He probably will, but it's an hour drive one way so I was hoping to find out something ahead of time. Especially with gas being almost 4 bucks a gallon. lol
Old Apr 19, 2012 | 09:02 AM
moss500berg's Avatar
moss500berg
Same bolt pattern, 5x5.5 right?
Old Apr 19, 2012 | 09:32 AM
Wombat Ranger
Roger that.
Old Apr 19, 2012 | 10:13 AM
classicfins
Yep, same bolt pattern. I'm just concerned about the offset. The newer wheels look as though they will set further inward than the stock steel wheel. I don't mind it being offset to the back a little more, as long as it doesn't end up looking too weird or making contact with the frame or something. I haven't be able to find a chart or anything to compare the back space on the newer wheels. I am going to contact the guy again today and see if he'll measure the backspacing for me.
Old Apr 19, 2012 | 10:37 AM
Stockers should have a 4.5 to 5 inch backspacing. If yours is in that neighborhood.... should work fine.
