1995 4x4 ram 1500 Has trouble shifting, backfires.
Old Apr 21, 2012 | 04:56 PM
Dodgehazz92's Avatar
Dodgehazz92
Default 1995 4x4 ram 1500 Has trouble shifting, backfires.
When i'm driving and it goes to shift (auto) it sort of stumbles, hesitates(sometimes backfires) shifts, then runs fine. Idles fine and all. Replaced the TPS sensor a while back, it was faulty. Any ideas guys? it has no cats, so clogged cat eliminates that possibility..It's really bugging me and iv'e research this issue and alot say cam position sensor??? Help... Trying to sell truck, it wont sell this way-
Thanks!!
Old Apr 21, 2012 | 05:02 PM
Check fuel pressure..... possibly cam sensor... but, I don't see why it would only do it when it wanted to shift....
clean your battery terminals as well.
Old Apr 21, 2012 | 05:04 PM
Dodgehazz92
fuel pressure is good,battery terminals clean, havent done cam sensor, how does this correlate with shifting?
Old Apr 21, 2012 | 05:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Not saying it's your problem, but just because you eliminated the cat(S) does not mean you eliminated the plenum problem. Anyway, besides that I'd maybe take a look at the crank sensor and o2 sensor.
Old Apr 22, 2012 | 03:27 AM
Dodgehazz92
the cat(s) were not clogged. I could see daylight threw them, every little square was perfectly boxed. on both cats-I removed them because a few months ago i had a multi cylinder misfire, and in turn this poisoned my cat.Failed inspection, whole 9 yards..But before i add a new cat on there, i want to fix my current issue.Any help is appreciated.
Old Apr 22, 2012 | 10:25 AM
Pacmanloads's Avatar
Pacmanloads
I had this exact problem for a couple of months, it was a bad distributor cap .
Old Apr 22, 2012 | 02:32 PM
Dodgehazz92
it only acted up when shifting?????
Old Apr 22, 2012 | 02:36 PM
Dodgehazz92
if it is the cap, i will flip S*** bought all tune up parts at same time at autozone, spark plugs were faulty and now this?
Old Apr 22, 2012 | 02:37 PM
zman17's Avatar
zman17
When was the last time the cap and rotor was replaced? Get a brass terminal cap. Loss of power causes all kinds of problems . It's worth a shot as Pacman suggested.
Old Apr 22, 2012 | 09:45 PM
Dodgehazz92
about 4 months ago, less then 6000 miles..
