Need some help please.......
Old Apr 23, 2012 | 04:33 PM
tommyb6273's Avatar
tommyb6273
ok thanks for all the help with the vac line. but im still having the starting issue. anybody have any thoughts on that....
Old Apr 23, 2012 | 04:39 PM
Leaky injectors? If one or more of your injectors 'dribbles' after shutdown, that would give you your symptoms..... Got a fuel pressure gauge?
You could warm the engine up, pull the fuel rail and all injectors, (leave injectors on the rail) disconnect the electrical connector at the coil, cycle the key a couple times to re-pressurize the fuel rail, and see if any of your injectors are leaking.
Old Apr 23, 2012 | 04:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Or bad fuel pump pressure regulator. A better than average fuel pressure tester will have instructions on how to test for leaking injectors also. It's as simple as pinching off the main supply line with the tester connected.
Old Apr 24, 2012 | 05:17 PM
tommyb6273's Avatar
tommyb6273
ok, thank you guys for all your help... ill check the injectors.
Old Apr 26, 2012 | 02:31 PM
tommyb6273's Avatar
tommyb6273
so i pulled the fuel rail today and the #6,#8 injectors drip about 3 to 4 times each. would that really be enough gas leaking to cause it to crank that long and smell flooded when it starts?
Old Apr 26, 2012 | 02:32 PM
Not really...... were they hot at the time?
Old Apr 26, 2012 | 02:49 PM
tommyb6273's Avatar
tommyb6273
it had been sitting for maybe 45 minutes when i pulled the rail. it was still giving off some good heat.
Old Apr 26, 2012 | 05:42 PM
zman17's Avatar
zman17
Without an inexpensive pressure tester, your just spitting into the wind.
