Park Pawlease...
Old May 8, 2012 | 06:54 PM
gdstock's Avatar
gdstock
If stuttering in 1st gear, i would think bands, not clutches. They normally just slip but not then suddenyl engage (in my experience).
Old May 8, 2012 | 10:38 PM
Soup is on.'s Avatar
Soup is on.
the lock up clutch is within the TC, so yes i guess that's what he was primarily referring to. But no, i don't have access to a scanner to read live trans data
Old May 8, 2012 | 11:34 PM
gdstock's Avatar
gdstock
TC is not engaged when you start off. It locks up in 3rd gear before OD kicks in.
Old May 11, 2012 | 05:31 PM
Soup is on.
no i don't have access to a scanner but gonna drop the pan tomorrow and see if ther's any parts or what not.
Old May 11, 2012 | 11:14 PM
Soup is on.
I'm gonna drop the pan tomorrow and have a look see...
Old May 12, 2012 | 08:37 AM
Soup is on.
if it's the bands, does that normally entale a rebuild? I've already been considering a shift kit cuz everything i've read about these trans is that the only way to make them last is an HD shift kit. But then i've also been reading that the 4.7 has the more favorable trans (not sure which model trans) which makes me wonder bout just swapping to one of those trans but haven't really seen anything on people doing that. Is that a possible solution?
Old May 12, 2012 | 02:29 PM
The 4.7 has a different bellhousing bolt pattern, so, the trans from those won't bolt up. Not to mention it is an electronically controlled trans.... and your PCM wouldn't have a clue... You would need to do some serious mods to make it work. You would spend less getting a megaviper....
There ARE 'repair' bands... that you don't have to tear the trans apart to get in.... but, if your bands are shot, most likely, the clutches aren't far behind.
Old May 12, 2012 | 11:39 PM
Soup is on.
so my trans isn't electronically controlled? If it's a 46re, i assumed the e stood for electronic. but i dropped the pan tody, didn't find anthing loose, wasn't really sure what to be looking for anyways but did find what i would believe to be a signifigant amount of shavings. No chunks tho. now my dilemma is, have the trans rebuilt or by a used one and install HD kit and slap it in. thought?
Old May 13, 2012 | 09:24 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Since you are having multiple mis fires. I'd take care of that problem first. Getting the engine running right might take care of the tranny problem.
Old May 13, 2012 | 04:41 PM
Soup is on.
misfire's are taken care of, but still having trans probs.
