pop when i pugged the head unit in no blown fuses
Old Apr 29, 2012 | 07:10 AM
4HoNdaDODGE's Avatar
4HoNdaDODGE
Idk what kindi dumbas* designed that I'm or a lot of things on that truch they make everythin a pita. I turn wrenches all day at work and I still get pis*ed when I work on that thing
Old Apr 29, 2012 | 08:59 AM
Augiedoggy's Avatar
Augiedoggy
that fuse works great when you have an intermittent slow draw that would otherwise kill the battery...I have to pull each night or the battery goes dead.....both times I used my meter to try and track it down I found nothing..
Old Apr 29, 2012 | 09:43 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Have you checked to make sure the glove box light isn't staying on?
Old Apr 29, 2012 | 11:14 AM
4HoNdaDODGE
That happend to me but would only kill my oold junk battery ... I know this is kinda off topic but how do you wire dual batter so it stays only a 12v system? And can the stock alternator handle that?
Old Apr 29, 2012 | 11:19 AM
zman17's Avatar
zman17
I have never done it, so I can't help, but there are threads on the topic. I know the search function sucks, but try it, and see what comes up.
Old Apr 29, 2012 | 05:31 PM
Augiedoggy's Avatar
Augiedoggy
I have not....
Old Apr 30, 2012 | 09:45 AM
zman17's Avatar
zman17
I have not....
I've seen the issue on DF more than a couple time's.
Old Apr 30, 2012 | 10:31 AM
hillbilli's Avatar
hillbilli
You run the second battery in parallel with the first. Connect the 2 positive terminals together and ground the negative. Stock alternator will be fine. Or you can use a battery isolator to keep the systems seperate and from draining each other.
Old Apr 30, 2012 | 11:34 AM
4HoNdaDODGE
Soo your say get another battery of the same kind and get an isolator? Where do I aquire one of them?
Old Apr 30, 2012 | 12:29 PM
zman17's Avatar
zman17
http://lmgtfy.com/?q=Battery+Isolator
