Transmission going out???
Old Apr 28, 2012 | 10:46 PM
kikidbird's Avatar
kikidbird
Default Transmission going out???
Lately my truck has been acting up and now it is getting worse. From a stop to acceleration, I really have to step on the pedal just to start moving foward. It almost seems like the parking brake is on. I was on the highway today and 55 mph @3000 rpm, it wouldnt shift. Had to take the side streets home. Jacked up the rear, smooth rotation and it ran smooth. Jacked up the front, noticed the upper and lower ball joints are worn, was suspecting the wheel hub bearings worn but there are good. Would my ball joints cause my truck to drag or is the tranny going out?
Old Apr 28, 2012 | 10:51 PM
Old_School's Avatar
Old_School
What motor do you have?? when was the last time the tranny was serviced?
Old Apr 29, 2012 | 08:12 AM
That's a trans problem. Along with the above questions, how many miles on the truck?
Old Apr 29, 2012 | 09:46 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Looks like a lot of work done to the truck. I see no mention about anything being done related to the intake manifold though.
Old Apr 29, 2012 | 10:32 AM
kikidbird's Avatar
kikidbird
My truck has 152,000 miles on it. The engine was OH aprx 2,500 miles ago along with a tranny service. The tranny was repaired at the dealer arround 40,000 mile, it was slipping still under warranty at the time.
Old Apr 29, 2012 | 11:12 AM
zman17's Avatar
zman17
So no work was done to intake? I'd check your cat before jumping into the tranny.
Old Apr 29, 2012 | 11:25 AM
kikidbird's Avatar
kikidbird
I replaced the plenum gasket
Old Apr 29, 2012 | 12:10 PM
zman17's Avatar
zman17
What about the cat? Was it checked? Do you know if the gasket was blown originally? Did you replace o2's?
Old Apr 29, 2012 | 01:03 PM
kikidbird's Avatar
kikidbird
Cat n 02 sensors good. Checked the DTC and pulled 0753. Checked my transfer case oil level and it is good. Unfortunetly the tranny oil level is almost bone dry, hopefully there is no permanent damaged.
Old Apr 29, 2012 | 01:44 PM
zman17's Avatar
zman17
In that case, you need to replace the TCC/OD solenoid unit. Sounds like it is in limp mode. And you do not need to take the VB off to replace.
