Opinions 360 rebuild time
Old May 1, 2012 | 12:34 AM
gdstock's Avatar
gdstock
Ouch. Low oil pressure is a good indicator of excessive wear in bearings. That bites...
Old May 1, 2012 | 12:49 AM
Moochoff's Avatar
Moochoff
Im going to check cylinder compression soon. Im hoping to get away with doing the bearings and not doing a complete rebuild for the time being... I guess we'll see
Old May 1, 2012 | 09:35 AM
Even if you DO have low compression..... so long as they are 100 pounds, or, in that neighborhood at least, you could just do bearings, and call it a day. Would get you by for a while.
Old May 1, 2012 | 10:40 PM
johnnyjaws98's Avatar
johnnyjaws98
go to your local rental place a rent a engine picker if you go on friday you can get it till monday for the same price
Old May 2, 2012 | 01:47 AM
Moochoff's Avatar
Moochoff
Thanks for the info guys... This is route I will probably go..
What will I need? Compression test kit, Caliper/micrometer, fresh oil, pan gasket, a few pages out of a manual... Anything else guys?
Thanks again!!!!!!
Old May 2, 2012 | 03:30 AM
mikeismadness's Avatar
mikeismadness
I'd go ahead and get enough oil and filters for 2 changes. After about 500 miles on those fresh bearings you will want to change the oil and filter again. Be patient with it and take your time :-)
Old May 2, 2012 | 09:07 AM
Just need some plastigage to check bearing clearances.
Old May 2, 2012 | 10:54 AM
Moochoff's Avatar
Moochoff
Even better, I forgot that it even existed lol... Im gonna try to knock this job out myself, and don't worry- Ill be back on here in a few weeks with more questions
