Problem fixed. Took the motor apart. There were leaves and stuff in there. Cleaned to the motor with electronics cleaner; used WD-40 on the bearings/moving parts. Went back over the moving parts with white lithium grease. No more noise. Could have been the leaves, could have needed a the CRC, could have needed the WD-40.
