looking into getting gears, need help
Old May 8, 2012 | 07:53 PM
97_ram1500's Avatar
97_ram1500
Default looking into getting gears, need help
well ive got the stock 3.55 gears in the rear and plan on doing a 2.5/1.75 lift and going up a size in tires. looking into putting 4.10s in. i know its gonna get it a little more umph but how will it do as far as mpg.
Old May 8, 2012 | 08:18 PM
Wombat Ranger's Avatar
Wombat Ranger
With lift and bigger tires you will lose a bit of MPG's, but gears will help you get some of that back.
Old May 8, 2012 | 09:32 PM
97_ram1500's Avatar
97_ram1500
do you think it would balance out or more to one side as far as mpg/acceleration
Old May 8, 2012 | 09:40 PM
Probably be about the same...... that is, if you go to 33" tires. (285/75/16) 4.10s are about perfect for that size.....
Old May 8, 2012 | 09:42 PM
97_ram1500's Avatar
97_ram1500
thats probably what im gonna do. but until then i plan put the gears in first, then lift and tires when my tires need replaced.
Old May 8, 2012 | 09:43 PM
You might like the grunt you get from the gears with the stock tires.
Old May 8, 2012 | 09:47 PM
97_ram1500's Avatar
97_ram1500
im hoping so. too bad it isnt coming from the engine where it belongs. haha (yet)
Old May 8, 2012 | 10:21 PM
lastrights's Avatar
lastrights
4.56 is better then you can always put 35 inch tires on down the road .
Old May 8, 2012 | 10:24 PM
97_ram1500's Avatar
97_ram1500
id love to see it happen to my truck but sadly its only a 2wd and isnt practical, although the idea has went through my head a good amount of times. haha
Old May 8, 2012 | 10:46 PM
lastrights's Avatar
lastrights
2wd would be awesome with 4.56 my cousins 96 ram was 2 wd and had them it moved good
