Cd player radio swap error message
Old May 12, 2012 | 06:12 PM
tssiTanker's Avatar
tssiTanker
Default Cd player radio swap error message
Bought a CD, Tape player radio off ebay for $62 to swap for mine that was just a cassette player. Said it was a good working Radio CD, Tape,player.
Hooked it all up and tried a cassette first goes it then it just spits it back out. So then I tried a CD stuck it in then it says ERR and it pops back out.
Just wondering if it has anything to do with that little hookup in the bottom left of the first picture. I don't know what it's for as I don't have anything that will plug into it.
98 dodge ram 1500
Old May 12, 2012 | 06:36 PM
stewie01's Avatar
stewie01
Just curious, did they say what that radio/cd/tape player came out of? It's definitely a factory piece. Is that a Chrysler logo I see on the screen or something else?
What's the white connection on the side of the device that isn't plugged in?
Old May 12, 2012 | 06:43 PM
gertie240's Avatar
gertie240
it sounds like the tape player and cd player are dirty. the tuner part works right? were you trying to play a mix cd? maybe the player cant read those. my wifes cassette player did that same thing after playing old recorded cassettes. you can clean a cd player with a qtip or buy one of those cleaners cds
Old May 12, 2012 | 06:44 PM
tssiTanker's Avatar
tssiTanker
Didn't say exactly what it came out of, Just said will fit 95-98 dodge truck.
And I'm not to sure on what that connection is for either. Didn't know if that could be the problem or not.
Also turns out Cassette player works fine, i was using a bad tape. CD player still doesn't work, tried 5 cd's and all get the same results.
Old May 12, 2012 | 06:49 PM
gertie240's Avatar
gertie240
yea, go down to most any store and pick up a cdcleaner kit, maybe ten buck. and a plus for putting in a mopar deck. i bought one off ebay too but havent got around to putting it in
Old May 12, 2012 | 07:14 PM
dhvaughan's Avatar
dhvaughan
it will likely only play true "audio" cd's, so if you are trying to play a CD-R or MP3 or homemade copy, that probably won't work.
as said, try cleaning it and using only original CD's. if that doesn't work, then you've got a bad unit.
Old May 12, 2012 | 08:06 PM
tssiTanker's Avatar
tssiTanker
Well I cleaned it with one of those CD player cleaning CD's that have the fuzzy things on the CD to clean the lens, and It does the same with original CD's. So I guess I will be returning. It just goes click click click and spits it back out.
Old May 12, 2012 | 08:25 PM
stewie01's Avatar
stewie01
Sounds bad to me.
Old May 13, 2012 | 12:26 PM
2000ramsport's Avatar
2000ramsport
does the radio work?does the clock on the radio go on?I wa thinking of doing tha swap to did the radio with the cd player fit into the hole where the other stero came out of easy?err sounds like you may have it hooked up wrong to me since both tapes and cds are not playing.if not send it back to the guy I dont trust e bay much anyway.
Old May 13, 2012 | 12:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by 2000ramsport
try the cleaner and see what it does.does the radio work?does the clock on the radio go on?I wa thinking of doing tha swap to did the radio with the cd player fit into the hole where the other stero came out of easy?err sounds like you may have it hooked up wrong to me since both tapes and cds are not playing.
Did you read the thread? He cleaned it(CD), and the radio and tape work.
