advice on rear end
Old May 17, 2012 | 09:15 PM
motorboatinjesus's Avatar
motorboatinjesus
Default advice on rear end
Hey guys would appreciate some advice. So my truck is making a whining noise from the rear end, after some searching i am assuming it is the pinion bearing. I am about to insure and use it to drive to work every day, how safe is it driving with a bad pinion bearing?
And once i get a few paychecks should I buy a used rear end and replace, or overhaul my current one?
Old May 17, 2012 | 09:19 PM
motorboatinjesus
I should mention it is about a 15-18 minute drive mostly highway
Old May 17, 2012 | 09:22 PM
Ham Bone's Avatar
Ham Bone
If you go the replace route, you might as well find one with a higher gear ratio. Like 4.10s
Old May 17, 2012 | 09:52 PM
dlyter09's Avatar
dlyter09
Bad pinion bearing can and will lead to destruction of entire rear end. Get it fixed before you start driving it. Mine was going bad and I ignored it for a while and one day doing 70 down the highway it let loose.
Old May 17, 2012 | 10:06 PM
motorboatinjesus
how loud was your whining before it happened?
Old May 17, 2012 | 10:09 PM
motorboatinjesus
Also, could humming whining be a u joint and not necessarily the bearing? If so, how would i go about diagnosing?
Old May 17, 2012 | 10:17 PM
DK-v1's Avatar
DK-v1
Get under the truck and start looking. See if there is any movement in your driveshaft/u-joints/slip yolks/etc...
There really shouldn't be any play.
Old May 17, 2012 | 10:29 PM
dlyter09's Avatar
dlyter09
Mine started out as something that most people would never pick up on. I could hear it with windows down and radio off. When it finally went I could hear it all the time unless I had the radio turned the whole way up
Old May 17, 2012 | 11:53 PM
motorboatinjesus
So i jacked up my truck, rotated the back tires and i could hear slight screeching. not too much play tho. turning them in reverse was alot more difficult. could the rear bearings cause this whine/howl?
Old May 18, 2012 | 12:01 AM
dlyter09's Avatar
dlyter09
Are your rear brakes hanging up by any chance?
