Tranny pan replacemsnt
Old May 20, 2012 | 04:25 PM
FFFD827's Avatar
FFFD827
Unhappy Tranny pan replacemsnt
hey guys. I found a nice red puddle under my truck today. I crawled under to see that the transmission pan has rusted through near the cat converter and is bleeding fluid at a pretty good rate. Has any one changed theirs? I assume if i get one from a junk yard it will not be in any better shape. do any of you know where i can find a good one under a hundred bucks? I found this on amazon any thoughts on this?
http://www.amazon.com/gp/product/B00...=dotinfo803-20
Its a 99 5.9 slt cc i think i have a 46RE i have a build sheet somewhere. Ill change the fluid and filter while its off.
Any tips or advise will be great
thanks!
Old May 20, 2012 | 04:29 PM
FFFD827's Avatar
FFFD827
I also found this
http://www.ebay.com/itm/Dodge-Ram-tr...f1631e&vxp=mtr
Old May 20, 2012 | 04:32 PM
stewie01's Avatar
stewie01
The ebay one looks to be a OEM replacement, which is fine. Going by the picture of the amazon.com one it's deeper which would require more fluid and appear's to have a drain plug.
So either one you want will work. Just be sure to fill it back up with ONLY ATF+4
Old May 21, 2012 | 12:55 AM
gdstock's Avatar
gdstock
I would not pay $77 for an OEM pan. The $129 Derale would be better for the little difference. Has drain plug. port ofr temp sensor, and cooling tubes. Deeper pan would increase fluid capacity and reduce heating. I bought one from a member here and really like it.
Go to a local tranny shop - they may give you one off a scrapped tranny. Or a few bucks at a JY - but NOT $77 for one!
Old May 21, 2012 | 01:01 AM
johnnyjaws98's Avatar
johnnyjaws98
get the deeper one
Old May 21, 2012 | 01:15 AM
crazzywolfie's Avatar
crazzywolfie
if you are looking on ebay for one you can get one cheaper than that. you just have to search using the right words.
http://www.ebay.com/itm/A727-A518-46...ht_1220wt_1037
Old May 21, 2012 | 10:04 AM
Josh_Putman's Avatar
Josh_Putman
Try here. I bought one for my mom's truck after the front u-joint in the front drive shaft broke and smacked the pan hard enough while whipping around to punch a big hole it in. I think it was about $34. It came with a silver coating of some sort on it that I cleaned off and bolted it on. They inspect them before they will sell them, so I wasn't worried about it, and it was in great shape.
http://www.allstarautomotivedenver.com/
I found them on Ebay, and then just went to their website. Hope this helps.
Old May 21, 2012 | 11:02 AM
gdstock's Avatar
gdstock
Searching seems to save money! I thought about offering ther OEM pan that I removed, but can't help but think shipping cost would exceed the price that it could be found locally.
