Manifolds
Old May 20, 2012 | 08:21 PM
Ram3602500's Avatar
Ram3602500
Default Manifolds
I recently bought a 2002 ram 2500 5.9 magnum and exhaust manifolds are really rusty should I change them or bring it to the dealer?
Old May 20, 2012 | 08:22 PM
stewie01's Avatar
stewie01
Dealer will charge you an arm and a leg.
Old May 20, 2012 | 08:25 PM
Ham Bone's Avatar
Ham Bone
If they're not leaking I wouldn't worry with em
Old May 20, 2012 | 08:53 PM
lastrights's Avatar
lastrights
Most likely its just surface rust . It should last a while unless there leaking
Old May 20, 2012 | 09:22 PM
Cast iron manifolds basically never wear out on gas engines......
Old May 20, 2012 | 10:18 PM
gdstock's Avatar
gdstock
...And will rust because of moisture in the air, expecially when they are hot.
Old May 20, 2012 | 11:13 PM
SilverSS's Avatar
SilverSS
+1 unless they're coated they all have some rust almost instantly.
Old May 21, 2012 | 01:20 AM
johnnyjaws98's Avatar
johnnyjaws98
put a coat of bbq paint on them
Old May 21, 2012 | 01:25 AM
crazzywolfie's Avatar
crazzywolfie
i would have to disagree with this. i tried bbq paint and it was gone in less than 6 month and i took all day to clean and sand blast my manifolds before paint. i think if you are going to try painting them you need to use an engine enamel with ceramic.
Old May 21, 2012 | 07:42 AM
SilverSS's Avatar
SilverSS
I used the vht 2000* flameproof paint on a set of headers. Didn't last long - maybe a few months.
